spark plug wires
Old 02-22-04, 11:28 AM
B
blazen30
Question spark plug wires
need 2 no procedure 2 check resistence of spark plug using ohm meter? thanx
Old 02-22-04, 01:03 PM
Need a Ohm meter to read 5,000-50,000 ohms. If you meter is not auto ranging set it to x 1000. Measure with a probe at each end of the wire with it disconnected.
Short wires will be around 5,000 ohms and the longer ones in the 15-20,000 range (15k-20k). Bad ones will be way beyond those numbers.
Old 02-22-04, 03:03 PM
Desi501's Avatar
I always used a rule of thumb of 10,000 ohms per foot of wire max.
