Car won't start
Old 02-22-04, 05:05 PM
B
Brian Hunt
Car won't start
I have an 87 celica - it has been sitting for a couple of months without being started. Tried to start it, nothing, tried jumping it, nothing - not even interior lights would work with cables hooked up - its like no battery is hooked up. One last thing - when the key is turned forward, it will come out of the ignition - it is possible that, when I tried to start it about a month after it had been sitting, that I removed the key with the ignition turned forward. I remember older cars had points that could burn out if the ignition was turned forward so wanted to mention it. Any ideas?
Thanks
Old 02-22-04, 06:07 PM
Desi501's Avatar
You need to install a "known good battery" before you can go any further. Remove that one and have it tested if you have to.
Old 02-22-04, 06:16 PM
B
Brian Hunt
Thanks - I'll swap one out of one of the other cars.
