99 GrandAm - Oil Light
Old 02-24-04, 10:32 AM
C
carlsdad
Lightbulb 99 GrandAm - Oil Light
1999 Grand Am 6 cylinders, 64000 miles. I got the oil changed <1000 miles ago and now the Change Oil light just came on. This light has never came on before even the time I was past due on an oil change. Took it to a new place (local dealership) to change the oil, but they supposedly use Valvoline which is what I always put in. I already have a touchy Check Tire Pressure light that drives me nuts, I don't know if I can deal with two!
Old 02-24-04, 11:02 AM
carguyinva's Avatar
an easy one...
press the RESET button located in the driver's side instrument panel fuse block
the CHANGE OIL indicator will begin to flash
press and hold the RESET button again until you hear a chime and the OIL CHANGE indicator go out
Old 02-24-04, 11:20 AM
C
carlsdad
Thanks. Any reason that this came on, or just one of those things? I don't even know what triggers it in the first place.
Old 02-24-04, 11:28 AM
carguyinva's Avatar
sure...
...it comes on somewhere between 3000 and 7500 miles...the service information doesn't explain the criteria but it has to do with the life of the oil rather than just the number of miles it's been in your engine...obviously 3000 miles on the highway is not the same as 3000 miles in town
the last place to change it didn't reset the light, i guess...
hope that takes care of it...
Old 02-24-04, 11:46 AM
C
carlsdad
Thumbs up
Thanks again!
