sunbird 94 2.0L check engine light (weird)
Old 02-24-04, 09:29 PM
maunor2000
hello ! can somebody help me? when i start my sunbird 94 it just doesn't run good, the engine feels like the fire is poor it cuts and after a while when the engine warms up the "check engine" light comes on,and the car runs like a new, as long the check engine light is on the car runs great.I go for a ride and when i shut the engine and restart it the light goes off and it stil runnin bad until the light comes on and it runs good again please help me?thanks
Old 02-24-04, 10:03 PM
mike from nj
a check engine light=a stored fault code.
either find a store that reads codes for free(autozone) or find out how to extract them yourself with a paper clip. if i knew exactly how, i'd tell you.
post the code number here.
Old 02-25-04, 07:46 PM
maunor2000
thanks i found the code it's 44 (o2 sensor lean exhaust) can someone help me with this? do i have to replace the oxygen sensor or what?
Old 02-26-04, 04:05 AM
Desi501's Avatar
Not necessarily. It's going to require some testing and further diagnosis. The most common cause for something like that is a severe vacuum leak. Look around for broken or disconnected hoses, leaking intake gaskets etc. The O/2 needs to be monitored while artificially enriching to see if it is cabable of going rich. It's going to require some equipment and knowledge to do this.
Old 03-08-04, 11:04 AM
maunor2000
thanks for the tips i check the vaccum hoses and nothing seems to be wrong..... can bad sparkplugs do this? thanks DESI501
Old 03-08-04, 02:55 PM
Desi501's Avatar
Not real likely on the plugs unless they've been bad so long that they ruined the O/2 but then you'd have both lean and rich codes in memory. It's going to require some testing with a DVOM. First you'll have to artifically enrich to see of the O/2 is capable of responding, then you can eliminate that as a possibility. If the O/2 checks good, then you have to start looking for the reason it is lean. Fuel pressure and vacuum leaks are the first suspects.
Old 03-09-04, 10:18 AM
maunor2000
thanks for your help Desi 501 i'm gonna double check the vaccum hoses.and what about the fuel pressure can it be to low or to high?
Old 03-09-04, 02:35 PM
Yes a lean exhaust can be from a fuel pressure or volume problem.Check it with a guage don't guess as it wastes time and effort.The pressure or volume would be low to set a lean exhaust code.
Old 03-09-04, 09:00 PM
maunor2000
thanks Davo for your help! what's the cause of low pressure is it the fuel filter that's pluged or the injectors dirty or else?
Old 03-10-04, 04:29 AM
Fuel pump could be weak,fuel filter dirty or a faulty fuel pressure regulator.Dirty injectors won't cause low fuel pressure but could cause a lower amount of fuel to be delivered to the engine.I would not think you have an injector problem though.
