1990 towncar
Old 02-25-04, 10:53 AM
mrltrnt
Angry 1990 towncar
I have a 1990 towncar with 5.0 engine aod transmission. park, n, r all work as they should. When I put it in od it will shift 1st then 2nd just fine but it goes into nutreul after that. If I put it into 3 it will not go up from 2nd. I was told both 3rd and od was out. But it doesn't make since, why don't it try to go into 3rd? I checked the outside of the shift cable it looks ok. It is over full by 2 or3 qaurts but I was told that wouldn't cause it. My wife overfilled it. Is there something inside that would cause this? it started to do this at once. Please help if can
Old 02-25-04, 11:22 AM
carguyinva's Avatar
sounds like the...
...direct clutch is toast...direct gives you third gear and I believe has to be on for OD as well...
