95 pathfinder
Old 02-25-04, 11:27 AM
gr8ful
95 pathfinder
4wd, 5sp, V-6.
Very sweet smell when running. There is not a coolant leak. Smells more like tranny fluid. I had it checked for tranny leaks and none were found. I also had the tranny fluid changed recently and the smell got stronger immediately after. At that time I learned that my catalytic converter heat shield had basically rusted away. I am going to do a new exhaust system this spring to take care of that. I'm wondering if the heat shield being missing could be heating the tranny fluid?
Any suggestions?
Old 02-25-04, 01:49 PM
fordman30
does it smell anything like rotten eggs? sounds like to me from what you are telling the shield being missing thats what it is doing ...so i would suggest not waiting until spring change it ASAP.LET US KNOW WHAT YOU FIND OUT
Old 02-25-04, 02:08 PM
gr8ful
not like eggs...
I know why you ask. This is not the c.c. I don't have an exhaust leak as I have checked all of that. It's just with all the salt etc. they put on the roads my exhaust rusted out and will need t be replaced. I was wondering if the lack of heat shield would contribute to the problem. This is definately a "sweet" smell, but it not antifreeze...no loss of fluid etc.
Thanks!
Old 02-25-04, 02:13 PM
D
Sweet smell equals coolant to me,if it's a real small leak it may be hard to detect and the coolant level could take a while to drop.That sometimes can be something like a tube in the radiator starting to seep.Look closer or have someone dye test the system.
Old 02-28-04, 02:13 PM
gr8ful
OK OK
You were right Dave, but, that's why I come here! Excellent advice...
I have a small coolant leak...working on that tomorrow!
Thanks
Old 02-28-04, 06:37 PM
fordman30
GREAT JOB DAVO
