Piston Rings
Old 02-27-04, 03:34 PM
Piston Rings
I got ahold of a 350ci chevy small block that the guy put chromoly
rings in. The problem is the rings never seated. Does anyone know of a way to seat the rings or do I have to tear it down & have the cylinders honed? It has about 5,000 miles on it.
Old 02-28-04, 07:34 AM
I would have to say if the rings haven't seated by now something was done incorrectly. Possibly incorrect cylinder wall finish, improper break-in, use of synthetic oil used etc.
Why do think the rings haven't seated?
Old 02-28-04, 08:30 AM
mike from nj
i was wondering the same thing
the crosshatch in the cylinders almost never disappears, not even after 200,000 miles.
a compression test or a leakdown test is about the only way to tell if the rings are good. or you could measure the ring's endgaps and see if they were correct from the beginning.
