Valve cleance
Old 02-29-04, 10:44 AM
Valve cleance
Trying to find what the valve clearance is for a 1986 Dodge Ram, 4 cylinder is i believe 1.5 liter
Old 03-01-04, 05:13 AM
carguyinva's Avatar
you'll have to give more info...
...is it a d-50? assuming it is since that was the smallest truck they made that year...i don't see a 1.5 L engine listed.
try checking the emissions label under the hood for the correct engine size...or post the 8th character in the VIN.
Old 03-04-04, 05:43 AM
carguyinva's Avatar
not being a dodge dude...
...i can only be sure of a couple things. one is that the engine is a mitsubishi 2.6 liter.
the other is that this a tricky adjustment and having the complete procedure in front of you will be of great benefit so you might want to go to the local library and see if they have a service manual...or possibly purchase one of your own.
the specs for valve clearance are as follows...
intake .006 inches
exhaust .010 inches
both specs are for a COLD ENGINE
