02-29-04, 01:14 PM
Tammie Day
How do you install a starter on an 1991 Cheverolet S-10?
Where is a starter ?
02-29-04, 01:20 PM
'91 S-10 starter
Should be on the right rear side of the engine forward of the transmission. It's usually held in by two bolts and has a large wire from the positive side of the battery and a smaller wire that comes from the ignition switch.
Disconnect the electrical wires first, then remove the bolts that hold it in. It may or may not have shims installed which you will have to reinstall.
Be careful though, the starters are a wee bit heavy.
HTH
Matt
HTH
Matt
