1999 Lincoln Town Car Executive(broken starter?)
Old 03-01-04, 06:40 PM
KnicksFan33
Engine: 8 Cylinder Gasoline
Trans.: 4 Speed Automatic with Electronic Overdrive
Fuel Type: Gasoline
Drive Type: 2 wheel drive
All right so here's what happened.
I got in my car and started it, no problem. Then for some reason I turned the key in the ignition again. Everything died; windows, lights, radio, everything. My friend brought his car over and tried to jump it. Everything started working again, but the engine still will not start. Did i blow out the starter or a fuse or the alternator or what? Thanks.
Old 03-01-04, 07:24 PM
fordman30
if it cranks but,no run i would start at the fuses under the dash and the fuses under the hood.to see if you have one blown.but if the starter dont turn over have the starter checked.
Old 03-01-04, 09:18 PM
KnicksFan33
re
Thanks for the reply. If I need a new starter, around how much would that cost?
Old 03-02-04, 06:39 AM
Received 1 Vote on 1 Post
For a 4.6 liter it should be about $120 + $50-$60 core charge
You get the core charge back when you return the old starter
Old 03-02-04, 06:46 AM
fordman30
i looked up auto-zone they have then priced at around 120.00 with a lifetime guarantee.the GUARANTEE means you will spend a lifetime takin it off and puttinn it on lol.but this should give you an idea.
