87 suburban no power under acceleration
funefarm's Avatar
03-01-04, 06:57 PM   #1
funefarm
I have replaced the control mod ,coil, dist cap & rotor, pickup coil, plugs & wires.I have set the timing with a vac gauge and timing light. I have replaced the fuel pump and filter. I can't seem to get any good power under accelleration, any ideas?
It has a throttle body on a 350 with auto.
fordman30's Avatar
03-01-04, 07:19 PM   #2
fordman30
my mine has gone blank.but anyway im thinking or trying to hows the injectors look.did you replace all the fuel filters.is the timing chain wore out.this is all i can think of right off hand .someone else will come along.so dont make any sudden decisions from what i said .
slickshift's Avatar
03-01-04, 08:24 PM   #3
Does it "stumble" when accelerating, or just lacks power?
How many miles on this vehicle?
How's your tranny fluid level?
Can you do a cylinder compression check?
By throttle body do you mean it is a throttle body injection engine with (a) big injector(s) on the throttle body?
Do you know the service history?
The items you changed are the usual suspects
You'll need to dive a little deeper
Any more info might help
smogtek's Avatar
03-01-04, 08:32 PM   #4
underpowered sub
Been awhile, but does it have a catalytic converter? It might be plugged.
Also might have a bad/disconnected knock sensor (if equipped). Had this happen to me on a '91 Sub. Knock sensor connector came off, timing retarded, BAM - NO POWER!
Just a few thoughts.
HTH
Matt
funefarm's Avatar
03-03-04, 07:51 AM   #5
funefarm
87 SUBURBAN
THANKS TO ALL I found the problem. It ended up being the knock sensor. I replaced it and reset the timing. It runs just about like new.
THANKS AGAIN for all your input,keep up the good work.
smogtek's Avatar
03-03-04, 04:35 PM   #6
87 sub fix
funefarm,
Glad we could help.
Matt
