4x4 problems for 96 ford ranger
Old 03-03-04, 09:15 AM
taddau
When I engage the four wheel drive, it feels like my locking hubs dont not hold. As they rotate to lock, they make a snapping sound and don't engage. I need to know an inexpensive way to fix this problem and where to start.
Old 03-04-04, 03:57 PM
You would need to take them apart and check them.They can be damaged if when you pull a wheel and the hub comes off and isn't put back on correctly.The hubs when installed must be 100% flush withe rotor or damage occurs very common.It takes a few tries to get them in the right spot.Some of the parts are plastic also.Take it to some mud or gravel and see if a front tire spins when you floor it.
Old 03-05-04, 01:13 PM
taddau
Thanks DAVO for the reply. Could the locking mechanism be stripped. I want to say the notch on the rotating piece of metal is worn down. Do you know of any inexpensive books I can refer to.
