77 F250 4x4
hotrod8645's Avatar
NJ
03-03-04, 06:10 PM   #1
77 F250 4x4
I asked a while back about a steering part that attaches to the frame on my 77 F250 4x4 that I didnt exactlty know what it was called and a couple garages didnt seem to know what it was either I am sending a pic this time I am also going to try uneedapat.com.
http://members.aol.com:/hotrod8645/webpic/steeringpart
SteelPanther's Avatar
03-04-04, 02:14 AM   #2
SteelPanther
That looks like a Pitman arm to me and drag link?
toyotaman11769's Avatar
03-04-04, 02:50 AM   #3
Are there lines that attach to the part on the drag link?
hotrod8645's Avatar
NJ
03-04-04, 02:36 PM   #4
yes there are four lines that attach to it
03-04-04, 02:56 PM   #5
It has to be some type of Power Steering control valve.
davo's Avatar
03-04-04, 03:01 PM   #6
It is a power steering control valve.Make sure you don't connect any hoses in the wrong place because the steering wheel may spin by itself under some real force.It also needs adjusted but I forget the specs.
davo's Avatar
03-04-04, 03:02 PM   #7
Meant to ask why do you need a new one?
hotrod8645's Avatar
NJ
03-05-04, 09:17 PM   #8
I need a new one because it leaks fluid so bad after driving an hour I have to add more fluid the main use of this truck is snow plowing so the steering gets a lot of use
u2slow's Avatar
03-06-04, 07:55 AM   #9
u2slow
That control valve is a common problem.
This place sells them on exchange for $400 - I assume they're rebuilt.
http://www.73-79fordtrucks.com/
You truck's steering is the "power-assist" type. In mid-77 they changed to true power steering. Converting to the newer style steering box is possible, but some fabricating is required.
http://www.ford-trucks.com/articles/powerassist.php
Another cheaper possibilty is to convert to manual steering. (If your arms are up to it )
hotrod8645's Avatar
NJ
03-06-04, 07:02 PM   #10
Thanks guys you have been a big help
