throttle linkage
Denise47's Avatar
03-03-04, 07:23 PM   #1
Denise47
throttle linkage
I have a GMC 4x4 serria S15 truck my throttle to my gas broke at
the point it connects to carberater -its on a bracket . my manuel
does not give me much info--could use more info - I have extra
line to connect it threw--but would input before i mess with it.
toyotaman11769's Avatar
03-04-04, 03:00 AM   #2
You have to replace whats broken. I never heard of having "extra". Go to the dealer and they will be able to give you a parts printout of the setup and order the correct part.
The throttle shouldn't be "rigged" it's a saftey issue.
Denise47's Avatar
03-04-04, 08:19 AM   #3
Denise47
Throttle cable
Thank you for replying--Yes you are right about safety issue-after looking at the cable I had relized it. I did call and get the correct
part--but don't have a clear view of exactly how to remove old cable and replacing it? my manuel has alot on everything but one
paragraph on just adjusting it which helps but is there a certain way of taking it off and putting the new on??
03-04-04, 08:42 AM   #4
Some times by looking at the new part you can see how it attaches.
