Caravan wheel bolt pattern
GregH's Avatar
Super Moderator
CANADA
03-06-04, 07:52 AM   #1
I need a temporary spare tire for my '95 Dodge Caravan with 14" standard rims and would like to know if a 14" rim from an '88 Dodge Dynasty would fit.
GregH.........HVAC/R Tech
mike from nj's Avatar
03-06-04, 08:38 AM   #2
mike from nj
rim size doesn't matter, tire size doesn't either(for a temp spare)
the bolt pattern should be the same, however i think the caravan might have a bigger 'register'. the dynasty is based off a "K" (aries) platform, and should have the smaller hole in the center of the rim, i don't remember when they started using the bigger registers on the caravans(they're a different platform, and should be slightly bigger)(i could be wrong too). i would say the caravan rim would have no problem fitting the dynasty.
of course it might have like 1/4" different offset and hit the brake caliper, that you would only find out at 3 in the morning.
that should be the only difference, a trial fit 'before' a flat is always the best way to find out
GregH's Avatar
Super Moderator
CANADA
03-06-04, 09:22 AM   #3
Thanks Mike,
Now I know it's worth a test fit, and not a temper fit on the highway.
