95 grand am, 2.4lt. f/i Cuts out at 4000 rpm`s
Old 03-07-04, 11:01 AM
reyes45's Avatar
my wifes 95 grand am has a problem that i can`t figure out.
wether driving or in park as soon as rpms reach 4000 it cuts out
and then ill have a hard time starting it again. I replaced the fuel pump, fuel filter, fuel pressure regulator, air filter ign. module wires, cap and rotor and also new plugs. I dont want to throw any more money away. any sujjestions will be greatly appreciated.
Old 03-07-04, 11:11 AM
I would check for codes, Autozone and the like will check them for free. Report back with your findings.
Old 03-07-04, 11:24 AM
reyes45's Avatar
I get no code readings and no check engine light at any time. some one told me it could be the cam positon sensor.Does this sound right.
Old 03-07-04, 11:35 AM
Well could be a lotta things....
We could roll out the ole dart board, but....
You need to hook up a fuel preesure gage and see what the pressure is when it cuts out.
Old 03-07-04, 12:47 PM
reyes45's Avatar
do I need to check the fuel pressure even after I just put in a new fuel pump, fuel filter and fuel press. reg.
Old 03-07-04, 01:51 PM
Yes! or you could keep throwin darts!
I knew you were going to respond with that answer.
What happens if you have a voltage or ground problem back to the pump.
Thats the difference between some who diagnoses a problem and some who Guesses by throwing parts at it (or throwin darts, makes as much sense!)
Old 03-07-04, 02:00 PM
reyes45's Avatar
thanx toyotaman.
I never thought about the possible foulty conections.
I will check the fuel pressure and return with more imput.
thanks again.
