Need Help With A 1994 Ford Thunderbird Lx
STR8BLADEZ's Avatar
03-07-04, 04:43 PM   #1
STR8BLADEZ
OK HELLO PPL HOPEFULLY SOME ONE CAN HELP I NEED TO KNOW HOW TO REPLACE THE DRIVER SIDE DOOR PINS IN A 94 FORD THUNDERBIRD LX.....CAN ANY ONE HELP
toyotaman11769's Avatar
03-07-04, 05:01 PM   #2
Hi Welcome to the Forums
Just to let you know caps use over the internet is considereded SHOUTING.
As for your problem is the hinge worn? The hindge is replaced as an assembly. All the bolts and nut are accessible in the door jam.
Get the hindge at the dealer, it comes unpainted. Use a jack with a piece of wood or a whole bunch of wood to support the door. Scribe the old hindge at the door and pillar, remove the hindge and install the new one to the marks.
STR8BLADEZ's Avatar
03-07-04, 06:05 PM   #3
STR8BLADEZ
ok it is the pins in the hinge i need to know how to replace the pins.........thank for the info tho
Desi501's Avatar
03-08-04, 03:16 PM   #4
You drive it to the dealer and let them do it. For what they charge it's a lot cheaper than the grief you'll go through trying it yourself.
