weak spark
Old 03-10-04, 04:34 PM
89blaze's Avatar
weak spark
GM HEI external coil. spark plug on coil wire to check for spark, small spark for a couple seconds and then dies. assume bad coil. meter broke, ate by dog. any other way to test coil?
or would you suspect sumptin else?
Old 03-10-04, 05:18 PM
Desi501's Avatar
Other than making it jump a spark over 1 inch, the only other way is with an ohmmeter. Look up the spec and check the resistance of both primaty and secondary.
