dodge want start
socool371's Avatar
TX
03-11-04, 12:00 AM   #1
dodge want start
having problem getting the 1990 Dodge Dynasty with a 3.3 liter engine to start their is about 120.000 miles on it every time i turn the key it will turn over like it going to crank but does not had a gas filter put on but still sounds like it not getting any gas it is fuel injected too and how i go about getting the car codes on this car need help fast and a hurry
Desi501's Avatar
03-11-04, 04:17 AM   #2
Codes aren't going to be much help. You need to test for four things.
1. Spark at the plug (checked with a spark tester)
2. Injestor pulse (tested with a noid light)
3. fuel pressure (and quality of fuel)
4. Compression (referring to valve timing)
One or more of those things is your problem. When you find out which, it will be easier to find the cause.
