clutch fluid question
Old 03-11-04, 06:05 PM
i have a '95 Chevy Cavalier...130,000 miles...2.2 liter coupe..standard transmission...the clutch fluid reservoir is low (empty) of fluid...the cap or cover of the reservoir says to refill using brake fluid...but the manual says to use "clutch" fluid...are these one and the same?...have had no problems w/the clutch, just was checking fluid levels for maintenence purposes...
Thanks to all who reply,
Matt
Old 03-14-04, 03:57 PM
bri208
Just relax and pour, they are one in the same.
Old 03-14-04, 04:19 PM
thanks for the info...
Old 03-15-04, 04:59 PM
Desi501's Avatar
Now the bad news......you have a leak. You shouldn't ever have to add to that. You have either a bad clutch master or clutch slave cylinder. Most times we change both at the same time.
