fuel pump
Old 03-11-04, 09:31 PM
Question fuel pump
Are there any symptoms that might indicative of a fuel pump problem?
I have 1995 Chevy Corsica (V6). It has lost allot of power at acceleration and will hesitate at various points. A friend who had a 1994 Corsica thought this sounded like a fuel pump problem he had. But, I didn't really want to just throw parts at it.
Thanks,
Shawn
Old 03-11-04, 09:53 PM
fordman30
i would try cthe cheapest way first ...,changing the fuel filter<s>converter could be stopped up.
Old 03-12-04, 01:18 AM
To start diagnosing the problem you to need to check fuel pressure while your having the problem.
You can rent a gage at some of the auto part stores.
Old 03-13-04, 10:14 AM
How often does the fuel filter need to be changed?
Old 03-13-04, 10:24 AM
I like to do it once a year or at least every 15-20k miles.
Old 03-13-04, 10:43 AM
mike from nj
yes davo, those are good intervals.
or you could just change it when it's clogged solid.....but you would need a gauge to figure that out.
it would be a shame if a clogged filter overloaded and wore out a good fuel pump.
