1996 Ford Contour Miss Fire
mopar2die4's Avatar
03-13-04, 12:52 PM   #1
mopar2die4
I have a 1996 Ford Countour 4 Cyl the car runs good when cold but when it warms up it acts like it is running on 3 cyl I have tryed replacing the coil and it did not help at all. any Ideas?
Auto Doc's Avatar
03-13-04, 09:48 PM   #2
Auto Doc
Have you replaced the plug wires? It could be a spark plug wire breaking down.... also, check to see if oil is leaking through the valve cover gasket into the area where the spark plugs are...
