Striped Spark Plug
jabari's Avatar
03-15-04, 07:35 AM   #1
jabari
Striped Spark Plug
What is the best way to remove a striped spark plug out of the cylinder head of a 1995 2.2 L S-10? I already know Ez out. Can this be used with the head on are does it have to be off?
toyotaman11769's Avatar
03-15-04, 10:05 AM   #2
How is it stripped? Is it that it will not turn, the hex is stripped? The plug is out but the threads are messed up?
jabari's Avatar
03-15-04, 10:55 AM   #3
jabari
It will not turn counterclockwise. The procleain and the hex nut are fine. It seems that when the plug was reinstalled it was cross threaded. It is not causing a miss or backfiring, the spark plug itself is in good shape.
03-15-04, 11:24 AM   #4
Spray with a good rust penetrant and try it after it sits cold for 8hrs or more.
Desi501's Avatar
03-15-04, 04:40 PM   #5
It's not exactly legal but you could spray some freon directly on the plug and nothing else and that will shrink it slightly. If it's an aluminum head then it's just seized and will take part of the head with it when it comes out.
jabari's Avatar
03-16-04, 06:59 AM   #6
jabari
When I remove it will I have to replace the Head or just rethread it or is it a 50/50 chance.
03-16-04, 07:16 AM   #7
Maybe able to rethread or they do have kits that install a sleeve with threads in it.
They can be done on the car.
Desi501's Avatar
03-16-04, 04:56 PM   #8
It's called a Heli-coil and it was God's gift to mechanics. They are lifesavers. Make sure you install it straight though.
