door repair?
Old 03-15-04, 08:40 AM
speedotoy
door repair?
Just wondering if anyone out there would know where I can get a diagram of the internal workings of a 99' silverado door. thanks for any help.
Old 03-15-04, 10:16 AM
carguyinva's Avatar
your local library...
...may have a service manual...altho most service info now comes in electronic form. most of that stuiff is line art anyway and only somewhat helpful.
if you tell us what's wrong or why you want to get inside the door, we may be able to help you with descriptions and pointers
Old 03-15-04, 12:06 PM
speedotoy
re. door problem
I was turning the key and heard a loud pop, and now the door will not lock. passenger door is fine but I want to fix the driver door if possible by myself. I figured if I could see the internal workings before I pull the door apart I will have a better idea of what went wrong?
Old 03-15-04, 07:21 PM
Yes, My Tempo had the same problem and it was the little plastic part that raps around the lock cylinder and connects to the latch control rod. This plastic part is probably broken and is not expensive($5)Go to the parts deptmt of your dealership and ask for a replacement.
Old 03-15-04, 08:22 PM
door lock
......... and they may even give you a screen printout from the computer showing all the parts if you ask them nicely!
This isn't a hard fix other than having to remove the door panel and get your hands into small places.
Matt
