90 olds minivan
lee0323's Avatar
03-16-04, 07:26 AM   #1
lee0323
90 olds minivan
i have a 90 olds minivan and it is missing. i replaced the plugs,wires,dis cap,rotor and it is still missing. i was wondering if it could be the cat covter. that is the only thing i can think of.i don't want to take it to the shop and find out it is somthing i could of fixed myself please help or tell me what i can check.
picklesnouts's Avatar
03-16-04, 12:57 PM   #2
my take is its a..........
vaccum leak somewhere. Maybe the intake manifold has a bad gasket or you have vacumm hose that fell off or has rotted. A miss to me means bad plug or lean mixture. How did the plugs look that you changed? If some were extra light color, that could be a lean mixture caused by tooooo much air!
Desi501's Avatar
03-16-04, 02:52 PM   #3
Most of the one's I've had acting like that had dirty fuel injectors. GM V6's are notorious for that and there are numerous TSB's on the subject. Get a profession pressure cleaning. It surely won't hurt and likely will fix the problem. Don't bother adding anything to the tank, that's not strong enough.
