Check guages light flashing
cheese's Avatar
GA
03-16-04, 10:45 PM   #1
My neighbor has a 1993 pontiac Grand Am. Her "check guages" light is flashing, and the "oil pressure" light is flashing. The oil pressure is very good on the guage, but the needle jumps a bit. I haven't had time to check actual pressure with a real guage, but I am convinced it has ample pressure. I wanted to ask around to see if maybe this was a fairly common occurrence and if so, what causes it. (I looked at it at the roadside for just a few minutes, and haven't had the time to do any checking other than telling her it should be fine to drive after listening to the engine under different conditions). I am thinking bad oil pressure sending unit or bad connection on it. I'm just not accustomed to these lights flashing. I'm used to a light just coming on. Anyone seen this before?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
davo's Avatar
03-17-04, 03:55 AM   #2
When you get to checking make sure the alternator is charging.I know it doesn't sound right but the alt can make that check guage system go nuts.
