1991 Honda Accord Rotors
Received 0 Votes
My girlfriend has a 1991 honda accord LX 4-door sedan. Front brakes and rotors need to be replaced. Can anyone confirm for me whether or not I need to remove the center nut (for the hub), in order to remove the rotor?
There's a plate in front of the rotor, that is attached by 4 bolts, to the rotor. I was able to separate the rotor from the plate, but the plate won't budge.
Any insight is appreciated.
Big job. That rotor is bolted to the hub which is pressed into the hub bearing. If your changing the rotor, buy a bearing now and send the whole knuckle to the machine shop to press out and change. The bearing will likely be damaged in the process.
Received 0 Votes
OK, for those who haven't had the joy of this job. Where's what I've done so far. In order to pull the transaxle out of the bearing, you need to remove the bolt on the lower ball joint, and pull the arm off, this give you enough room to pull the rotor and and all, out of the way of the transaxle. Then once I get that done, you need a 12 point socket to remove the four bolts on the back side. (and no you can't get at these bolts with out removing the transaxle first. the CV joint prevents you from getting a socket in wrench in there). Then once you get that done, I was hoping all would just fall apart. not the case. That's as far as I've gotten. Has anyone been able to remove the bearing and hub? How do I remove it? Do I have to remove the upper arm, too and take that whole unit to a machine shop?
Thanks in advance.
Thanks in advance.
if you take too much apart, you might disturb the alignment settings and need a front end alignment when you're done.
on older (early 90's, late 80's) dodge colts(imports), i take off the axle nut, bolt on a slide hammer and pull the rotor and half the bearing off. this gets resurfaced on the lathe(or replaced) and bolted together using the axle nut to draw it back together. the tapered roller bearings look destroyed, but it pulls right back together and works quietly when done.
not saying this is how your honda is, but it seems most imports have a common theme on how parts work and come apart.
Received 0 Votes
I vote for the machine shop with the press,I've never been able to slidehammer an Accord rotor off and trust me we tried a 10 lb one and it didn't even budge.It will work on most other cars though.
Received 0 Votes
mission accomplished. I ended up taking the entire steering knuckle off the car, and bringing to a garage to press out the bearing, replace the rotor, and then put it all back together, pressing in a new bearing. Put it all back together, and brought it back to the same garage the next day for an alignment.
Thanks for the help.
Just to add a little information on this particular job. I have done many of them. The entire knuckle must be removed and the hub pressed out before the rotor can be removed for machining or replacement. Also I have never HAD to replace the bearing. As long as it is done properly the bearing should be fine.
Hope this helps,
Billy
Hope this helps,
Billy
ALL FWD vehicles should be aligned this way
because the handling of these designs is VERY affected by the rear. aligning all wheels according to the centerline of the vehicle is really the proper way. during 4 wheel alignment, 2 extra reference points are added to the process by installing the rear sensors/projectors...that's how the machine forms the geometry of the suspension.
It's not really a choice. The design of the vehicle determines what type of alignment the car takes. You can't just do half of it. The front takes it's reference from the rear.
Received 0 Votes
1991 honda accord rotor replacement
