My horn doesnt work!!!!!!!
I have a 1993 Olds cutlass ciera. My horn stopped working . I noticed a cliking on the relay so thats sounds ok. My next stop was the horn. I pulled it out and connected it directlly to the battery. I sounds good. So my question is the problem the wire between the horn and the relay? If so how to i go about to find it. Or is it easier to run another through there. Any suggestions are appreciated.
Just because the relay is clicking doesn't mean it is good. Use a testlight at the horn and see if you are getting current there, if so, check it coming out of the relay. It may be a plug problem right at the relay.
