A/C on my car
Old 03-22-04, 04:48 PM
gigglejump
Lightbulb A/C on my car
Hi
Looking for the answer if anyone can help.
I have a 1980 Cutlas supreme , my a/c blows out from the bottom,
but i cant get it to blow out from the vents on the dash board.
Please help
what could it be??????
Old 03-22-04, 08:56 PM
no AC upper vents
Usually means the doors that direct/redirect airflow aren't changing positions.
I don't know this particular vehicle, but if it isn't electronically controlled climate controls, you've most likely got a defective or disconnected vacuum control hose.
Without vacuum, there's no control.
HTH
Matt
Old 03-23-04, 05:26 AM
Desi501's Avatar
Not much question, it's a door problem. The unusual thing is that it usually defaults to defrost in the absense of vacuum. It could be one of the doors stuck. Check both things.
Old 03-24-04, 06:39 AM
carguyinva's Avatar
vacuum supply line from under the hood...
...or the rotary vacuum switch in the control part in the dash.
Old 03-24-04, 01:16 PM
Desi501's Avatar
Re: vacuum supply line from under the hood...
Are they still using those things? I thought they upgraded some by now. This car is kinda old.
Old 03-24-04, 01:44 PM
carguyinva's Avatar
rotaries...
used back then...not any more
