Gm Code 43
Old 03-23-04, 02:24 PM
Gm Code 43
Hi all,
I have a 92 full size cehvy pick up with a 5.7 liter. Throttle Body. The truck recently started running very badly and is throughing a code 43 and 33. Any suggestion on where to start?
Thanks,
Brian
Old 03-23-04, 03:34 PM
Desi501's Avatar
The code 33 is the important one. It indicates MAP sensor voltage too high. This could be a bad sensor but is more likely a broken or leaky vacuum line supplying it. Inspect the line/hose very carefully all the way back to it's source. Look for any other vacuum leaks that could be lowering the vacuum overall.
The code 43 is a knock sensor code
The ECM did not detect a knock signal during near wide open throttle operation with coolant temperature above 194 F or the knock signal was present for 5 seconds or more during normal engine operation.
Electronic Spark Control (ESC) Circuit .
That one may be a little more complicated. Fix the MAP problem and clear the computer and see if any come back.
