1996 Mazda Mx6 Engine Surges
MIKESR's Avatar
03-23-04, 02:29 PM   #1
MIKESR
I HAVE A 1996 MAZDA MX6 THE RPM SURGES (UP & DOWN) WHEN THE COOLING FAN ENGAGES. RUNS FINE WHEN THE FAN IS OFF. MIKESR.
Desi501's Avatar
03-23-04, 04:47 PM   #2
That may be related to your A/C problem in the other thread. The fan coming on and the computer triggering an "idle up" may be the ECM trying to engage the compressor with no response from it.
smogtek's Avatar
03-23-04, 05:14 PM   #3
surging
Tell us some more about the car.
Any recent repairs or other problems other than the A/C mentioned in your other thread?
Matt
MIKESR's Avatar
03-25-04, 05:46 AM   #4
MIKESR
Re: surging
Matt
Hi Matt, My grandson just bought the car and I don't know the history. It's when the engine cooling fan engages the rpm goes (on the dash) from 1500-550 rpm. The engines almost stalls out. When the car was bought there was a clutch engagement problem. the clutch was suppose to have been changed, but, I feel it engages low. The car is in use now. Thanks, MIKESR.
MIKESR's Avatar
03-25-04, 05:54 AM   #5
MIKESR
Sounds understandable, but, with the a/c switch is off and the engine cooling fan comes on, the engine surges from 1500-600 rpm and almost stalls, would the ECM still try to engage the a/c? Thanks, MIKESR.
smogtek's Avatar
03-25-04, 05:37 PM   #6
I'd start by disconnecting the power supply wire/connector from the AC compressor, start it up and see what happens. If no change try the following:
Some engines will surge if the coolant is low. Check the cooling system and make sure you have the proper amount of coolant in the system and all the air is bled out. If your engine does not have a bleeder port in the cooling system, you can also bleed it by loosening the coolant temp sensor or temp sending unit.
They are usually located near the thermostat housing.
Matt
MIKESR's Avatar
03-27-04, 01:00 PM   #7
MIKESR
Thanks so much it looks like I'm on my way, MIKESR.
smogtek's Avatar
03-27-04, 02:48 PM   #8
what was the fix?
Curious minds want to know. LOL!
Matt
