rusted license plate screw
Old 03-26-04, 10:42 AM
gclausen
Unhappy rusted license plate screw
I'm not able to remove a rusted license plate screw. I've tried freeing it up using "liquid wrench" without any success. I've also tried to grab it with a pair of vice grips, no go.
At this point the flathead screw driver slot is pretty much stripped.
Any suggestions?
Old 03-26-04, 03:18 PM
Davejb's Avatar
Pick up a screw extractor kit from your local hardware store, always a good thing to have for the shadetree.
Old 03-26-04, 03:27 PM
BSparks294
You could with the aid of the trusty hacksaw blade--make another grove in the head. At the very least you would have the head closer to being removed and then you could drill out center with a normal bit and use plastic next time. Brad
