Ford F100 I-beam suspention
Old 03-26-04, 04:40 PM
sp0832
Where can I find a diagram or exploded view of how the front king pins and bushings go together for a 1966 Ford F100. Are there any on-line manuals?
Old 03-26-04, 06:52 PM
D
Have you removed the king pins yet?If not this is best left to someone with a good press.I suggest removing the I beams and send them to a machine shop you won't be sorry.When they are replaced grease them once a month.
Old 03-27-04, 07:21 AM
sp0832
Thanks for the info. I have already knocked out the king pins and I am in the process of cleaning up the I-beams and spindles. I am also going to replace the old rubber bushings with polyurathane replacements.
But I will take your advise and send all of it to a machine shop for proper assembly. I was going to assemble it myself after I had the bushings reamed out, but I think I will have them assemble them too.
Thanks again,
Eric
