Replacing
Old 03-29-04, 04:19 PM
The Mrs.
Smile Replacing
I really need to know how to replace the instrument panel lights on a 1994 escort. Also what is the correct timing setting on the same car?
Old 03-29-04, 04:34 PM
fordman30
TIMING SET IS AT 10 DEGREES BUT IT NOT ADJUSTABLE.IF YOU THINK YOUR TIMING IS OFF MAYBE IT IS TIME TO REPLACE TIMING BELT AND GEARS.HOW MANY MILES DO YOU HAVE ON IT
Old 03-29-04, 04:36 PM
You'll have to remove the instrument cluster to replace the lights.
If I remember correctly, the timing is 10 degrees BTDC, but I also believe this model has a non-adjustable distributorless ignition system (DIS).
Matt
Old 03-29-04, 09:00 PM
You must remove the steering wheel, inst. cluster
Loosen-remove all those switches on the steering column and loosen up (or remove) the rest of the dash
10 degrees BTDC
Non-Adj. DIS
What is the mileage?
Replacing the timing belt on these is no problem for a handy DIY
