96' Sunfire hazard flasher problem??
Old 03-30-04, 04:30 PM
C
Question 96' Sunfire hazard flasher problem??
Hi,
I own a 96' Pontiac Sunfire.I have a problem with the hazard flashers...
When you put them on only the front lights and flashes,the back doesn't??
Yet all blinkers,lights seem to work fine?Any ideas on this?Thanks
Old 03-31-04, 02:29 PM
D
The problem would most likely be the t/s/hazard flasher or the turn signal switch?Do you have a wiring diagram for your lights?If you do I will give you directions to attempt to determine which is at fault.You could try the flasher but I offer no guarantees.
