90 integra brake problem
Old 03-31-04, 07:35 PM
W
WGW
WGW is offline
I've just replaced the rear rotors and pads on my 90 integra. Everything fitted well but after assembling, the brakes are so tight that I can't rotate the wheels.
(Yes, the pistons were pressed back into the calipers)
If I took it out for a drive, would the pads adjust, or burn off the excess or would that just over heat the rotors?
Other suggestions?
Old 03-31-04, 11:26 PM
mike from nj
your rotors and pads would be ruined before the pads would wear away.
start taking things apart until you find the thing that is causing the bind. a little drag is normal, the tire should be able to turn at least one full revolution with a good spin. that's how tight i make drum brakes. disc brakes 'self adjust' this tight themselves.
some things to look at, the e-brake mechanism, whether it's a cable going into the caliper, or a separate set of brake shoes inside the center of the rotor, try backing that off and see if it helps.
