fuel and oil sending unit
Old 04-02-04, 10:33 AM
R
Where is the fuel and oil sending units located on a 1988 GMC K2500, my fuel and oil pressure gauges does not work and I need to locate them and also how do I check them to make sure that is the problem. Thanks for your time
Old 04-02-04, 05:00 PM
Desi501's Avatar
If those 2 gauges stopped working at the same time, the senders are not the problem. It's going to be an electrical issue in the dash. Not going to be easy for a DIYer. You'll have to be able to read a schematic and identify the components in the circuit.
Old 04-02-04, 06:13 PM
R
No they did not stop working at the same time, I have replaced the instrument panel. The oil pressure gauge stopped working about 3 months ago and the fuel about 1 year ago. Thanks.
Old 04-02-04, 06:38 PM
Desi501's Avatar
The oil sender in on the engine block and the fuel sender is in the gas tank (logical).
If you ground the oil sender wire, it should read max. I don't think that will work with your gas gauge though.
