'93 Civic Power Windows Won't Work
Old 04-02-04, 12:12 PM
b_lauren
I'm having a problem with the power windows on my '93 Honda Civic. A couple of weeks ago I could no longer get my driver's side passenger window to go down from the switch on that passenger door or from the main panel on the driver's door. And now none of the windows are working. Even the power locks have stopped working.
Any ideas on what the problem could be.
Old 04-02-04, 04:15 PM
D
First check fuses and then inspect the wires in the drivers door rubber boot for breakage.Pull each wire separately the break may be internal and the insulation will give a little at the break area.
Old 04-09-04, 08:52 AM
b_lauren
Thumbs up
Thank you very much for the help. It was just the wires and I was able to get it fixed.
Thanks again.
