93 mercury
Old 04-02-04, 04:33 PM
jbull69
93 mercury
I have a 93 mercury grand marque with several problems. first how do i fix the turn signal it stays on but doesnt blink. second the windshield washer doesnt work i can hear the motor(?) running under the reservior. help
Old 04-02-04, 04:36 PM
Desi501's Avatar
The turn signal problem, if it is only happening on one side is likely a bad bulb. If it's happening on both sides, check the flasher. Your washer problem may just be plugged nozzels. Unhook the hose before the nozzel and see if it pumps at that point.
