starting troubles
Old 04-03-04, 06:19 PM
tommey1966
Angry starting troubles
I have a 1984 ford mustang 302ci, carberated. The car will only run when the starter is engaged, as soon as i let off the key the car dies. I replaced the ignition switch, coil, voltage regulater, and solenoid. What do i need to do to get up and running again?
Old 04-03-04, 09:31 PM
Sounds like an open wire or connection in the solenoid circuit.
Start by checking your connections/wires, especially from the solenoid to the ignition system.
HTH
Matt
Old 04-04-04, 05:59 AM
Check the ignition module they have start and run circuits in them and are wired as such.If you have power on the wire to the run circuit I would bet on a ignition module.
