02 Chevy help
Old 04-03-04, 11:02 PM
withdog81
Question 02 Chevy help
Please help I have an 02 Chevy Malibu and I want drain the radiator but I cant find the plug I spent all day tring to find it and no luck. I dont want to remove any hoses, if anyone knows how to do this I really need to hear from you. I want to drain and clean
Old 04-04-04, 03:43 AM
Desi501's Avatar
I don't understand why you would be draining that fluid at this time. That car should be equipped with DexCool which GM says should last 5yr/100K. Going that long can cause problems but it should be at least good for 3yr/50K. Do you have that much on it.
Sometimes removing a hose is the easiest way to get it drained. If there is a drain, it can be really hard to access anyway.
Old 04-04-04, 05:42 AM
D
The drain plug appears to be on the passenger side of the car facing the engine.If you really need to change the coolant and its easier to pull a hose I would do so as Desi said.
Old 04-04-04, 07:52 PM
withdog81
02 Chevy Malibu Radiator
Thank you all for the help I found the drain plug. It is on the drivers side and it was right in my face, the end of the radiator drivers side very bottom.
