Voltage output too high
tarbender's Avatar
04-04-04, 09:47 AM   #1
I have a 98 plymouth voyager,3.3L . First I thought I had a starter problem, with it just clicking a few times before starting. When I checked charging voltage with vehical at idle I was getting 18 volts. Not good. Possible voltage regulator inside Altenator or inside PCM? Any way of testing ?The manual says it's in the PCM and need to change entire PCM?
Desi501's Avatar
04-04-04, 03:05 PM   #2
Re: Voltage output too high
That's a fact. There are ways to wire in an external regulator but I can't tell you how to wire it from memory. Maybe Mike from NJ will be able to help you with that.
mike from nj's Avatar
04-06-04, 02:36 AM   #3
mike from nj
on the back of the alternator there is one big fat wire(battery) and 2 little wires. one of the little wires (green with orange tracer) is 12 volts from a relay(that's not your problem), the other is the field control wire(it controls the charging rate) this wire goes directly to the pcm. if that wire is chafed anywhere and grounded, it will cause the alternator to overcharge(if it were unplugged, the alt would never charge). you need to ohm that wire from the alternator to the pcm, with both ends unplugged. if it has continuity to ground, that's your problem. if it has continuity, but not to ground, it's could be a pcm.
look for chafing near the dipstick tube, and possibly the top of the trans. look everywhere between the alt and pcm, but those places first.
then let us know what you find.
