1973 Corvette will not start
Old 04-09-04, 09:12 AM
Billm10454
When I try to start my corvette the starter is turning slowly as if the battery is about to run out. I used a portable starter with the same result, I also used jumper cables with the same result. Could this be a starter problem. Thanks
Old 04-09-04, 05:10 PM
it could be a starter problem or a cable or bad connection start by checking your cables making sure they are clean and tight both at the battery, starter and engine block, if they are and it cranks over slow all the time no difference when engine is cold or hot i would suspect the starter.
Trackbacks are On
Pingbacks are On
Refbacks are On
