95 chevy cavalier
pikepanther73's Avatar
04-09-04, 04:02 PM   #1
pikepanther73
95 chevy cavalier
Would EGR valve cause hesitation or the car to die after car is warmed up, when at a Red light and you give it gas the engine bogs down and quits. the car will start back immediately until you try to pull out again and will do the same thing.
bejay's Avatar
04-09-04, 04:52 PM   #2
while the egr may cause a hesitation it usually will not cause the car to die under acceleration, it may cause the car to die when idling or coming to a stop when you let off the gas.
sounds like you may have a fuel pressure related problem suggest you have fuel pressure checked and see if it loses pressure under acceleration.
