4wd not engaging
spells's Avatar
CANADA
04-11-04, 06:39 PM   #1
4wd not engaging
1999 GMC Envoy 4.3L 4wd auto.Its push button to engage drive modes. It only works on 2wd Hi and 4wd Lo but will not engage 4WD Auto or 4Wd Hi. Any Ideas?
boardslinger's Avatar
04-12-04, 12:37 AM   #2
boardslinger
I've yet to see one of those automatic locking 4wd units NOT seize up. You're probably better off converting it over to manual locks. But I'm sure one of the resident experts here will have a way to fix your problem. Good Luck
carguyinva's Avatar
VA
04-12-04, 04:33 AM   #3
you can't convert to manual...
...locking hubs. take it to a competent tech and have it scanned for codes. it may have a bad encoder motor...it may just need to be exercised. sometimes they freeze up due to lack of use. good luck...
davo's Avatar
04-12-04, 04:39 AM   #4
You need to have atc codes checked to accurately diagnose it but I would suspect the mode switch is faulty(dash select switch).I think you may find a mode switch malfuntion code stored,if so replace the switch and clear the code.B2725 is the code # for the mode switch.
