Gas Tank Repair
Old 04-17-04, 08:05 AM
Ronald0207
Gas Tank Repair
I have a plastic gas tank for a motor cycle what is the best way to patch or repair this. I've tried silicone and it does not stick.
Old 04-17-04, 09:49 AM
tank repirs
On metal tanks, depending on the size/location of the repair, I might have a recommendation. And only as as "temporary" measure.
Since this is a plastic tank, I'd suggest just replacing it if possible.
Combustible plastic + gasoline + spark = accident/tragedy waiting to happen.
JMHO
Matt
Old 04-18-04, 12:14 AM
mike from nj
i'd second the replacement option.
i sure wouldn't like 1.5 gallons of extremely flammable gasoline leaking between my legs as i ride. all it takes is a drip to hit the hot exhaust and you will lose all will to live. plus, without a fire extinguisher, stop, drop, and roll doesn't work. you will have a fire until all the gas is gone.
most street bikes have steel tanks, if this is an off road or a dual sport bike, you can find aftermarket (and larger capacity) tanks in a lot of magazines that specialize in 2 wheel things.
silicone never seals a gasoline leak, gas dissolves it. if you can find an epoxy to seal it, it will crack the first time the tank flexes(which is soon).
Trackbacks are On
Pingbacks are On
Refbacks are On
