1991 Dodge Monaco loss of power
Huxley's Avatar
04-17-04, 10:33 AM   #1
Huxley
I will drive the car for about 6-7 miles and at that point the power will go down 30 to 40 percent. It repeats this pattern every day. I have check all the fuilds and they are full. At first when it did it was only a small lose of power but now it has worked it's way up to about 30%. Engine size 3.0 mileage 151,000 auto. transmission. Has had the problem for about a month.
Thanks in advance
smogtek's Avatar
04-17-04, 02:04 PM   #2
Sounds like a fuel or ignition problem.
You need to check fuel pressure at idle and under ACTUAL driving conditions so you can see what happens during the power loss.
You also need to check or replace the fuel filter and check the ignition system.
If you can get us this info, we should be able to point you in the right direction.
HTH
Matt
Huxley's Avatar
04-17-04, 03:08 PM   #3
Huxley
Can they test fuel presure while driving the car?
Desi501's Avatar
04-17-04, 04:33 PM   #4
Sure, you'll have to tee in a fuel pressure gauge and run it up under the cowling and maybe tape it to the windshield so it can be seen while driving. If by chance that doesn't turn out to be the problem, you may try dropping the exhaust to check for a plugged cat. That would give symptoms like that also, especially with the high mileage like that.
Huxley's Avatar
04-17-04, 04:52 PM   #5
Huxley
I should also note that it losses power no matter what speed you are going.
mike from nj's Avatar
04-18-04, 12:31 AM   #6
mike from nj
and i'll be the 3rd person to recommend a fuel pressure test, WHILE the problem is happening.
for curiosity sake, how old is the fuel filter?
Huxley's Avatar
04-18-04, 08:11 PM   #7
Huxley
Fuel Filter is on about 50,000 miles
How often should it be changed?
smogtek's Avatar
04-18-04, 08:41 PM   #8
About every 12-15K. I'd say it's about time.
Huxley's Avatar
05-06-04, 07:05 PM   #9
Huxley
When a fuel pump goes out will it quit all of a sudden or will it go a little at a time?
