mazda fuel pump relay
Old 04-18-04, 04:25 PM
pt_fixer's Avatar
Anyone know where the fuel pump relay is on a 95 mazda protege(1.6L)? I have a no-start situation and narrowed it down to fuel delivery. Found the fuel pump not to be working, but no voltage to the pump. Ran a jumper directly from the battery to the pump and its working. So now I just have to track down that relay. I've got one of those bobo service manuals, so it is no help.
Old 04-18-04, 07:33 PM
the_tow_guy's Avatar
Received 67 Votes on 56 Posts
Likely it's going to be in a location with other relays/breakers/fuses. Check under the hood in a plastic housing with a pop-off cover. Should find a diagram of the box contents under the cover that will tell you which is the pump relay.
Old 04-19-04, 05:00 AM
carguyinva's Avatar
according to AllData...
...it's at the right front of the console area...the picture is kinda crappy but it looks like passenger side front of the console and hanging in the harness.
ps...i looked for a 1.5 L engine...it's either that or a 1.8...there is no 1.6
Old 04-19-04, 04:32 PM
pt_fixer's Avatar
Thanks for the speedy replies. Found the relay just as you described it carguyinva. Never would have thought to look there. All by its lonesome. And its a 1.5, I mistyped it. Now its time for a sorely needed tune-up and it should be purring like a kitten again. Thanks again.
Old 04-20-04, 04:52 AM
Gotta love that Alldata!
TG
