1988 Camaro VSS
maitai11's Avatar
04-20-04, 05:33 AM   #1
1988 Camaro VSS
Hi,
1988 Camaro, 5.0, Throttle Body Injection, 700 R4 Trans.
Where is the VSS located? Also, after putting the car on a lift, I noticed a wire hanging(with a connector) from the trans. The other connector in the wiring harness is plugged into the trans. I looked and looked, but could not find a place to plug this second connector into. What am I missing here? I am also considering that perhaps something has either fallen off the trans or does not exist any more for some reason (previous owner mod, etc)
I also have a code 24 from my ECM
help anyone?
Thank you,
Maitai
carguyinva's Avatar
VA
04-20-04, 08:10 AM   #2
the VSS harness...
...is probably what's hanging disconnected. it goes at the rear of the trans on the driver's side. it may be somewhat difficult to see because of the crossmember or other bracketry. it's there tho...good luck
