98 caravan frt discbrakes
jgood45823's Avatar
04-21-04, 12:39 PM   #1
jgood45823
im having trouble,lining the caliper mounting bolts up seems to be a lot of tension&can get only one bolt in what can i be doing wrong? I seem to have the proper pads. thank you
davo's Avatar
04-21-04, 03:16 PM   #2
The calipers on those have a little lug that has to go over the caliper bracket if you look close you will see what I mean.Also you need to keep the sliders held back from the bracket while installing the caliper.Tip: sometimes putting 2-3 lugnuts on finger tight to hold the rotor against the hub can be a blessing.
jgood45823's Avatar
04-22-04, 05:25 AM   #3
jgood45823
re 98 caravan discbrakes
Dear Davo,Igot the brakes on but they seem to be grinding&squeaking do you know what could cause that?Thanks!
Cabot's Avatar
04-25-04, 08:52 PM   #4
Brakes
On my 99 Voyager, it was a common problem. Cheap pads would sound like they are grinding and squealing, just started to put middle of the road pads on and that cleared it up. These minis eat front brakes for lunch, so, keep the rears adjusted and that will help out the fronts.
